1990 --25hp ele st remote carb issues !!!!!
osborne looney
took carb off cleaned it seemed to run ok for a lil bit then back to same ol problem starving for fuel will run with choke but not on it own !! either I missed something or ? my question is can the jet tube be removed on this carb (6-holes in tube with small one running inside) that goes to bottom of float bowl ?
picture does not show but here is A CLOSE facimily
Likely you missed removing / cleaning the high speed jet.---It is screwed into the carburetor bowl.-----Screwed in horizontally and about 5/8" long.
Likely you missed removing / cleaning the high speed jet.---It is screwed into the carburetor bowl.-----Screwed in horizontally and about 5/8" long.--Do not remove other tubes.
JDusza
Couple things...
Check the gas. If you cleaned the carburetor and it worked for a while then quit, you may have crap in the gas. Do you have in-line fuel filters?
Check the fuel lines to be sure there are no air leaks.
Check fuel pump by removing line at carburetor, wrapping with rag and turning starter over. Fuel should be pumped into rag. If you run well at high speed you can discount this. Does the engine run at high speed? Does it run at all?
Not sure of this carburetor, but, I think the low speed jets are still be clogged. How did you clean them? Ensure the jets are clean with a fine wire and acetone.
What's the model number of the unit?
J
osborne looney
Couple things...
J
#22/23/25 on my pic at beginning post shows these but on my and neighbors motors these do not exhist just bowl drain plugs for some reason
I will remove again and get a better look-see but they are not present
MODEL # E25ELESE
Nonsense.---------That high speed orifice plug is there.------All the fuel must go through it for the motor to run.----Take the time to do a proper inspection !!!
