1990 115hp pistons
swick73
I have a 1990 115hp that I had to get two cylinders bored .044 over because who ever had the boat before me had a bad case of stuck rings untill they broke and scored it up. Now im trying to find a gasket kit and 2 sets of standard piston rings and 2 hard to find oversized pistons .044 over any recommendations of where to buy and at a reasonable price? by the way i live on the coast of mississippi
Faztbullet
Re: 1990 115hp pistons
Ouch!!:eek: Since you went to .044 your stuck with Wiseco pistons, if you went .040 you could have stayed with a cast piston (Pro,Vertex,WSM).Call Promarine as they usually have everything in stock. Below are part #'s...
Pistons.................3173P4.....X2
Rings...................3940.........X2
gasket set............499..........X1
Crank seal kit........1733-2......X1
impeller................3059.........X1
t-stat kit.............2658A........X1
carb kits.............7046V........X2
gel seal..............GS1-2.........X1
rod bolts............RB5000........X8
swick73
Thanks, they had to bore over .044 cause of the scoring. Not exactly what I was hoping for:(
