1989 Rinker
Britinusa
Hi all, i recently bought a 1989 Rinker Fiesta Vee 250 in need of some TLC
Im putting in new floor in the cabin, the head wall was rotted so im replacing that
The old Head wall, plain white Melamine and it was rotted at the bottom
New floor going in, the old floor was uneven fiberglass
Im laying a vinyl floor from Plasteak over this, i will fiberglass the seams before the floor goes down
New head wall test fitted
New head wall stained and refitted, this will have a chrome porthole mirror similar to the original
Old floor after the green carpet was torn up
tpenfield
How do things look towards the stern of the boat? That is usually where the trouble starts and then it works its way forward to the cabin.
Britinusa
The boat is in great shape, it had a window leak so the carpet was wet and dirty and smelly, so i decided to rip it out,the floor was all rough fiberglass and i wanted a vinyl floor so i had to make a new sub floor to even it all out.
The head wall rotted because there was a leek where the step drain goes into the head and joins the sink drain then they both go out the starboard side, and the cabin bilge pump was disconnected, i wired it up and it runs again.
Rickmerrill
Nice attention to detail. I like that door porthole, you make that from scratch?
Britinusa
Thank you, the door with the porthole was the original head door that had rotted, the new one will have a chrome porthole mirror.
Britinusa
The floor is all in, im not fiber-glassing it because in putting a vinyl floor down and the adhesive will not work on fiberglass this is a mock up of how the stripes in the teak and holly floor will be oriented, the steps will have the vinyl on the tops and the front faces will be stained the same as the head wall.
Britinusa
I need to figure out the table mount, im going with a surface mounted floor piece, since im using padding under the floor vinyl, im concerned that when i attach it the floor around the mount will be pulled down and may distort the lines, Any thought?
redneck joe
mark around the base, cut out vinyl, install table and caulk around the base?
Britinusa
Thanks guys Im thinking or cutting the padding and putting a spacer in there and leaving the vinyl uncut, like this
