1989 Rinker With Quicksilver Control wont lock into Neutral..
alldodge
How can I tell which controller it is...
Got to the link and place the cursor over each listing. A pic of the control shows up. Find one that looks like yours. Find it and then select the link and explore the parts breakdown. This is how we would do it if you posted a pic of your control
alldodge
In the link, its the lock pin which is not engaging. When you squeeze the handle latch, does it spring back when released? If it does then its inside the rod or lock pin. If it doesn't then might be the spring
Rinker Scott
Yes when I squeeze the handle and release it it springs right back out
