1989 mercruiser 4.3
Dhicksaw
When at wide open throttle its almost like I'm running out of gas actually anything above 3000 rpms boat slows down then speeds up. I have changed the exturnal water seperator cleaned the screen in the carb. The thing runs great at any rpms beloow 3000. Any help would be great
Thank you
Dennis
hivoltg
Re: 1989 mercruiser 4.3
I would check for cracked fuel hoses. The cracks will suck in air under load. A sign of this is smelling fuel when the boat sits.
slothman
sounds like a fuel issue. Maybe one of the jets in the carb is clogged. Have you ever had the carbs cleaned ? A clogged carb will cause exactly what you are starting. Slow down, speed up, slow down, cut out, etc.
Dhicksaw
Thanks for the help I will check the jets in the carb
Ayuh,.... 'n the Fuel Pump,...
'n the Anti-siphon valve,...
'n the tank's vent,...
What did you find in the fuel filter, 'n fuel screen,..??
