1989 Johnson Prop Change
kingkhan
i would like to know how to change my prop, what tools will i need, and basically what i need to do, any help is greatly appreciated
Thanks
Aaron
JB
Re: 1989 Johnson Prop Change
Engine model??
Chris1956
AAron, First of all the prop really needs to want to change...
Sorry, bad pun.
Your motor probably has a cotter pin, nut and spacer over the prop. Remove the pin, put a 2X4 between the gearcase and the prop blade, and using a big wrench, unscrew the nut. Remove the spacer and then the prop. There is a thrust washer under the prop. Remember to replace that before you install the new prop. Grease the splines of the propshaft before instaling the new prop.
