1989 Johnson 40hp running on one cylinder
Tubes66
So I rebuilt the carbs and checked spark and everything looked good , has all new fuel line and no leaks , compression is 90 lbs in both cylinders and have been messing with it to get it to run right and noticed that it's not running on the bottom cylinder. What could it be it's definitely getting fuel has great spark and has the same compression as the other cylinder
Compression is way too low.----My gauge would show 140 on one of those motors.---Bottom crankshaft seal checked ?-----What happens when you spray some fuel into the bottom carburetor ?
Tubes66
Spray staring fluid in the bottom carb when running and it does nothing , and how do I check the crank shaft seal . Even without spraying starting fluid and pulling the bottom plug after running the plug is super wet so it's getting fuel .
Little Richard
So spark is jumping 7/16 inch gap. Strong and consistently. Do you have a timing light where you can confirm cylinders are firing and at the right time.
Tubes66
I'm going to try a 7/16" gap tomorrow, how do I check timing , never done timing before ...
Check crankcase compression on bottom cylinder.-----I would remove cylinder head for inspection ?----Head gasket is cheap.
Tubes66
So I was just messing with it and noticed and a little higher Rpms then idle the cylinder starts to hick up and fire a little bit
Tubes66
Spark is jumping the 7/16 great ..... really stumped . What is pulling the head off gunna prove
