1989 Johnson 120 running issues
Brian85
Hello,
I have an 89 v4 120. I have been trying to get it running after recently purchasing it on a boat. It runs great on the flush tool but as soon as I put it in the water it wants to die. It doesn't want to idle or at low RPM. If I go wide open it will run but poorly. Then you can hear the engine kind of straining to run. I rebuilt the carbs. I have the service manual but I can't find the compression numbers to compare to. These are the numbers. Left top 100 left bottom 91, right top 100 right bottom 90. I know the engine was ran hot but not to the point of tightening all the way up. It just confuses me out of water how it runs perfect. Any help would be greatly appreciated.
Brian85
Bump. I was told it is a back pressure issue being that it is having the problems when in the water. Bad power pack?
Honorary Supreme Mariner
It is NOT running perfect on the trailer.----It only sounds that way to the untrained ears.---Do you have strong spark on all 4 leads ?---Carburetors clean ?---Those compression numbers are a concern.-----If motor overheated I would remove one cylinder head to have a look in there.
