1989 Force 85 hp questions
shawn.54
My son is looking at a 18’ spectrum boat with a 89 force 85 hp motor. I’ve owned Mercury Johnson evinrude but never a Force I need some schooling before he buys. Any weaknesses I should know or things to check. Or even let me know to run away.
shawn
Nordin
Chrysler/Force are old school designed engines and very easy to work on.
They were designed in the 60.s and 70.s, the only big thing which was up dated was the ignition systems and the piston design .
Before buying check compression and spark at all 3 cylinders.
Does not matter of brand, always check compression and spark.
If it is possible, run the boat in water and check how it perform and the cooling system,
Remember Chrysler/Force do not have a telltail as OMC and Mercury.
They have idle relief holes at the back of the midleg.
The weak thing on Force 3-4 cylinders are the piston rings, the top ring has very little land to the piston top.
They tend to break and score the cylinder walls.
The 3 cylinders has three carbs, one feed each cylinder.
If a carb get clogged or running lean the cylinder will score after a while.
jerryjerry05
Good running motors.
I had a pair on a 21 center console.
They were in salt water most of their lives, the mid section/transom mount gave out after 20+years.
No real problems after the introduction of the newer TCW-3 oil.
If you keep it out of the mud and sand(shallow water) it should last a long time.
The over heat buzzer/system is weak. I added a motorcycle horn so I could hear it if it got hot,
under normal operation, I never heard the horn.
Regular maint. and this motor can last a lot longer.
Like Nordin said, compression test. Run it.
shawn.54
What is acceptable compression. I’m going to make a trip to check out the boat.
shawn
Nordin
Factory spec. from new says 135-155PSI, but down to 120PSI is acceptable.
Most important is that they are about equal, not more then 10% in difference.
jerryjerry05
The 89 85 should have 145-150
But the gauge you use can make a HUGE difference.
Cheapo gauges= cheapo results.
Harbor Freight gauge is crap.
The results need to be within 5# of each other.
But as long as all 3 are even then it should be OK
shawn.54
Ok thanks for the information going to check it out today going to set up a water test also.
shawn
