1989 force 50 hp
lizardlover1
I need help i recently purchased a 1989 maxum bow rider with a force 50 hp outboard on it . When i took it out for the first time it started great and idleded great then it started acting up ....... When i give it full power it starts out great then nothing andi mean nothing. It will run but its like there is a great weight holding me back . It wont plane out at all ..... I have replaced all the fuel lines from the tank to the carb. But still the same. I know this thing should be able to go faster than 8mph at full power..... Im not a boat mech. But im not a idiot so any help would be great . Thanks
oxbeast1210
Re: 1989 force 50 hp
do you know the weight of your boat? what rpm are you seeing at WOT ? also have you done a compression test?
lizardlover1
ok guys i have replaced the plugs,fuellines,bought a aux tank so its all great ...... i do have a spare 50 for parts i took off the fuel pump to exchange and it wouldnt even cramk the boat.... so i put the old pump back on...... it has a very small prep on it would that be the prob.... also where can i find a carb rebuild kit for it ...
