randrews45
Thread starter- Joined
- Jul 10, 2002
- 3
I bought a Force 150 off of Ebay where the dealer did a bait and switch. He auctioned a 1990 motor as a newly rebuilt motor, then after my funds cleared, said that that engine was dropped by accident but had another engine with little or no use that was in mint condition that he could offer as a replacement. He checked it over, said compression test was OK and all looked like a new engine that was never rebuilt.<br /><br />I unfortunately took him up on it. When I had a local marine mechanic check it over, he found the head gasket was replaced, the compression was 155 psi on cyl 1, 123 psi on cyl 2, and 132 psi on the other 3 cylinders, the lower drive unit leaked out oil from the seals, the skag was broken completely off and rewelded back on,<br />and that the bottom 2 spark plugs were completely clean while the others were dirty (possibly bad lower carb). The seller insist that the engine is sound and that I or my mechanic don't know anything. <br /><br />I have heard that a variance of more than 10 psi between cylinders means the engine needs to be rebuilt. What I need is the qualified source that I can refer to to prove that this engine is not right or other things to look for to prove one way or the other what the engine condition is. I want the truth, I am not trying to only find the negative. This guy has lied to me on a couple of items. He has 470+ good transactions with 6 nuetral and 1 bad rating from buyers and sellers. I have not rated him yet.<br /><br />I may have to sue this guy which could trash his reputation on Ebay and Paypal for fraud. I have to be certain and be able to prove that this motor is a lemon or not. It appears to be a wornout piece of junk that he repainted to look good.
