1989 Force 125 prop options??
mos68x
I’m not looking for a specific propeller pitch, I’m just looking for currently available options of almost any kind (preferably new) since the local shops I’ve called so far have said that they don’t make anything for this motor. I would love to find a hub kit to convert to the newer stuff like Turning Point, but once again the same problem crops up. Any help would be appreciated, thanks.
roscoe
Well, in 1989 some models had thru hub exhaust, some had NON-thru hub exhaust. Need to determine which you have.
Look here in the iboats store.
For thru hub exhaust, Hustler makes a 3 blade prop, and Michigan wheel makes a 4 blade.
Some of the guys have had success using alternate props and hopefully they will be along soon to give you advice.
You may have to watch diameter clearances with the gearcase, and possibly use different thrust washers.
mos68x
I don’t have dual exhaust. I only have a single non-thru hub. Unless I can use the hub design of the dual exhaust I have very few options. Has any tried putting the dual exhaust hub kits on the single exhaust gearboxes?
