MinnesotaBum
Thread starter- Joined
- Sep 4, 2009
- 4
I have a 1988 evinrude XP 150 that was running great a week ago, then a few days ago it didn't want to idle very good but still ran good at WOT, I rebuilt carbs replaced all fuel lines and replaced the gaskets behind the transfer port covers(it looked as though they may have leaked a little) the pulse line to the VRO was also replaced and the check valve cleaned. I have good compression on all 6 between 102 psi and 106 psi. The VRO has been disconnected for many years with no problems. The work I did, did not help at all, it still would only run at WOT, after running for 15 min. or so I was heading back to the dock and it quit and would not start. After getting it home I checked for spark and there was none at all 6 plugs. I disabled the kill switch and still no spark. I am convinced the problem was not fuel and must a power pack, stator, or other electrical problem. Also when it started to act up I noticed the Tach had quit working, is this related? Any help on where to start would be nice, I really like this motor and would like to save it if I can do it cheaply enough.
