I purchased this motor after testing compression. 119 psi on all 3 cylinders. Rebuilt carbs. Oil pump was disconnected by previous owner and plugged. Motor starts up every time after priming bulb 4-5 times. Idles very high and fast for a few seconds then comes down. Once in a while stalls but starts right back up and then idles fine. After idling for a bit at dock and then trying to go out boat bogs at full throttle for a short distance then starts to take off and bogs again the takes right off and runs fine at full throttle. However when you come off throttle and try to go again does same thing all over. After sitting for and fishing for a while hard to start even after priming but will eventually start after working choke some. Has a 14 gallon tank which I am mixing 50:1. Looking at replacing VRO pump with regular pump from Maxrules.com along with main fuel line and primer bulb. Primer bulb never gets hard. However motor does not run any better by pumping bulb while trying to get it to take off, so not sure it is the pump. Any suggestions would be appreciated.
