mxzeatr
Thread starter- Joined
- Jun 2, 2010
- 188
Hello All,
Dad has an 89 50hp rude. It used to be VRO, but that had failed on another motor of ours so we put two delete kits on the other one and this one.
This issue started about 2 years ago, and he hasn't dealt with it much since. I'll try and describe everything with the best detail I can.
The motor starts and idles just fine. Just like new. You can run the boat (16' alumn runabout style) thru the entire power range for about 10 minutes. Then once 'warmed up' the motor starts violently jerking/missing whether there is a load on it (in gear) or not (just using throttle) it does it all the time. But you can idle at 1/4 throttle all day long and the motor runs just as good as ever.
My guess (limited knowledge) is that there is a high speed stator that is out of it? My other guess is that this is under the flywheel. This is where another problem starts. We've left a puller on the flywheel for DAYS and kept it lubed with penetrating oil etc, it will not budge, we've smacked it with a hammer (not too much don't want bearing damage), we've even tried a little heat with just a propane soldering torch.
Does it sound like we are on the right track thinking its a stator? Any help with either issue would be EXCELLENT! Thank you!
