Ok so the motor has always been a little hard to start but Always started. I would usually have to sit and crank it a few times to get it to fire, before eventually it would start, but it would always fire. Once the motor was fully started and warmed up It would start first turn of the key for the rest of the day.
Well its been about a month ago I was running the boat and suddenly it slowly lost power. Took it to the shop, VRO pump went out. They also told me they had to put new spark plugs in just to get it to fire. I asked what fouled them and was told it probably happened when I lost power. Took the boat out following day started and ran fine. Took it out that weekend, also ran fine. Boat sat for about 2 1/2 weeks before I took her out again, I absolutely could not get the boat to start. Wouldn't even fire. I tried the following day to get it to start and never could get it to fire. Took it back to the shop and told them what was going on, they said It might be a power pack going bad. They called me that afternoon and said the boat cranked right up no issues... So I went and picked the boat up the following day at lunch, talked to one of the guys and he said they cranked if for about 5 seconds and it started. That afternoon after work I took it home and sure enough couldn't even get it to fire. Very confused. I didn't have the right size wrench to pull the plugs but I will this afternoon. Im going to see if the plugs are fouled, I have a feeling they are.
Im pretty frustrated because it always acts up at home and not the shop. Anyone have any suggestions on what to check first or what the issue might be?
