1989 evenrude tracker 40 overheating
trf900
I have a evenrude tracker 40 that I just had the water pump, head gasket and thermostat replaced by a local guy but engine is still over heating. Any ideas?
Complete water pump kit ?-----Did he replace the seal at the outlet of the pump?-----Needs to be there since it does not have a water tube.----Overheating with boat in the lake?---On muffs ?----Or in a tub of water ?----Running with VRO in service ? ----Mixing oil at 50:1 in the tank ?
trf900
I bought a complete water pump kit for the guy to install. It's running on muffs.
trf900
Boat sat up for 3 yrs and tge impeller froze up. Never overheated before.
Water that comes out the tell tale does not circulate through the block.------Could be an internal blockage.-----Any mud wasps in your area?
