R_Andersen
Thread starter- Joined
- May 3, 2004
- 78
I have a boat with twin 1989 DT200's that has sat for the last 5 years. I now have both motors running fine after going through them and doing water pumps. The problem is that I think the idle speed is too high. I am running them on the muffs and when warmed up they both idle between 1250 and 1300 rpm in nuetral. <br /><br />I have adjusted both idle speed switches and they do change the idle from agout 1250 up to 1400 rpm. I also checked the adjustments on the carburators and they are closing fully. <br /><br />I'm wondering if this is just due to them being run on the muffs with cold water or if there is some other way to lower the idle speed? <br /><br />Any help would be appreciated.<br /><br />Thanks,<br />Rob
