wayne77662
Thread starter- Joined
- Aug 23, 2004
- 2
Recently, while boating, one of the fuel lines fell off. I lost a lot of fuel, so upon discovering this I re-attached the line and loaded the boat on the trailer for refueling. I launched the boat the following morning and pulled two 10 year olds on a tube for about 5 minutes at which time the engine began to "sound" differant. After an investigation I found one of the oil injection lines off at one of the four carbs. I re-attached and stopped pulling tubers. The engine has a "rattle" under load but seems to clear up after the boat planes. The compression is exactly 140 psi on all four cylinders. Is it possible I have bearing damage but no cylinder damage? Is there anyway to verify without splitting the case? And if I do have bearing damage what should be my next step?<br /><br />Thanks, for the help!!
