1989 bayliner capri w/ 125 hp force motor
ronnlou
I just bought this boat. the tilt/ trim makes noise when i try it but does nothing. I tried filling it with tilt/ trim oil and ran it up and down, still nothing. When i tried lifting it by hand it squirted fluid from what looks like a plug on the pump motor by the bottom. do I neet to replace the motor? and if so do I need to replace the tilt and trim?
jerryjerry05
Re: 1989 bayliner capri w/ 125 hp force motor
If it's clicking and not running,I'd say the electric motor is bad.
The hyd motor is probably bad too.
Post a pic of the leak.
ronnlou
You can hear the motor running but it is not doing anything.
