rain-man64
Thread starter- Joined
- Aug 15, 2012
- 1
I have an 89 Alumacraft Super Bandit.. it starting taking on considerable water after I struck a partially submerged object in the lake. I checked the hull, no hole, after filling the boat with water, (on the trailer at home,) noticed several of the bulkhead fittings that had been previously siliconed, or siilyconed,as I seen it referred to on this site, where leaking, well looking for a quick fix to get through the rest of the summer, I cleaned off the old and put on new silicone.this helped a little, but after putting the boat back in the water,still taking on water.. after further investigation, found the transom is rotted, and water coming in through the outboard engine mounting bolt. i have said all this to say this.. does anyone have any experience replacing the transom board on this type bolt. it apperarsto be under a cap on top, riveted between aluminum..
