1989 85hp Force Head Gasket Replacement
supernuc1981
Can anyone provide me with the proper head torquing sequence and proper head torque for a 1989 85hp Force outboard. The model is 856A9A if that makes any difference. The head gasket recently blew around the number 3 cylinder and I plan on replacing it in the next couple of days once the gasket comes in. Thanks in advance for the info.
Frank Acampora
Re: 1989 85hp Force Head Gasket Replacement
Start with the two bolts in the center of the head and work outward in a spiral pattern. Torque the bolts in three steps: about 100 inch pounds, next about 180 inch pounds, finally 225 inch pounds. INCH pounds!
Run the engine for a while then re-torque the bolts. Re-torqueing is factory recommendation--sometimes I do it, sometimes I don't. It doesn't seem to make a difference. They don't get re-torqued after they leave the factory.
ldrive w
better have the head checked at a shop for a good surface .six thousands is about all.if the gasket blew chances are u have a warped head.
QuadManiac
Here ya go: Just like Frank said, but with pictures, lol.
Good Luck!
supernuc1981
Everyone, thanks for all the information. The picture is especially helpful. Also, I guess I probably should have the head checked just in case. Thanks again.
