just purchased this boat & motor, motor runs very rough only idles for 3-4 seconds then dies. took the boat to local shop for repair 20 yr exp. mechanic couldn't figure out what was wrong so gave it back to me with good luck? now the list<br /> rebuilt all three carbs<br /> replaced fuel filter/fuel lines /primer bulb<br /> replaced gas/checked fuel pump/new sp.plugs<br /> compression is between 98-95 psi all three cyl.<br /> good spark all three plugs <br /> checked for vaccum leaks at all hoses and lines-<br /> none found/ timing is dead on and advancing.<br /> exhaust ports do not seem blocked as this is a <br /> low time motor. I'M STUMPED.
