1989 200hp over heating
jj2975
Need help figuring this out. I have changed pump, poppet valve, t-stats. I have good flow and pressure but the water is steaming when it comes out of tail.
j_martin
Re: 1989 200hp over heating
You could be getting exhaust into the water through a bad gasket. You could also be plugged up somewhere so the water can't flow properly.
A water pressure gauge would sure help in the diagnosis.
hope it helps
John
jj2975
Thanks. I will try that. I also heard a bad head could cause this. Pressure gauge is coming. I will let you know. Thanks again. James
