1989 110hp Evinrude new coils run engine slow.
Deckworks
I picked up a used motor and was trying to update electronics since the old coils looked overheated. I replaced them with the same numbers as on the the coil packs which coincides with the numbers on iboats. With the old coils the boat pops up on plane and runs 40mph at 5200 rpm. With the new coils ( I have tried 2 different sets) the boat will slowly come up on plane and then top off at 28mph with a rpm topping out at 4200rpm. I have no idea what would cause this. Same numbers on the coils just new ones don't seem to work. When I put the old coils back on it runs great. Anyone have any ideas as to the cause? I'm worried I will need to replace in a few years and not be able to get the motor running at top speed or getting on plane.
Bosunsmate
do a drop test on each cylinder to test each cylinders working, maybe you got a new faulty part
Deckworks
I've replaced all 4 new coils with all 4 other new coils thinking the same thing. I get the same response to the new coils. It still runs great with the old coils. I've tried 3 sets of newcoils.
Bosunsmate
id ring up the seller and ask them, maybe your stator needs upgrading as well.
Ive 1982 coils on mine, so long as any cracks a filled in to stop moisture getting in they run fine
