1988
Johnshan1
Looking to buy this boat, it is clean with no rot. Are these boats good for ocean use? Can it handle some rough water? How large is the gas tank, the engine is a 5.0, how much hp? Good on fuel? How fast? Also how what would this package weigh in at?
Also the water pump is cracked from freeze up, mechanic said rest of engine was ok, so I take this as gospel? Is this pump the same as any automotive pump on a 5.0 (or close to the same idea) Any tips would be good, thank you for all the help!
HT32BSX115
Re: 1988
If the waterpump is cracked from freeze up ......don't touch it! Run away!
(That is, unless you can get it cheap enough to buy a replacement engine)
Cheers,
Rick
