1988 Suzuki DT40 oil injection sysyem
readynow
How would I know if the oil injection system was'nt working?
deejaycee_2000
Re: 1988 Suzuki DT40 oil injection sysyem
well ... you'll have a seized motor .... mark the oil reservoir and see if it uses oil ... premix your fuel just for incase, but the suzuki oil injection is very reliable .....
readynow
Thank you Captian.
er......what would the ratio of oil to fuel be?
will the added oil cause me other problems?
thanks again!
deejaycee_2000
Mix it 50:1 .... the added oil will just make the motor smoke alot, but won't cause any harm .... but fill the tank and then work out after the tank is finished how much oil it used form the oil reservoir and then you will know if it works properly or nit ....
readynow
We went out yesterday and the motor ran fine for over 45 mins. on the way back in a medium speed the noise started again.:confused::confused::confused::confused::confused::confused::confused
mmgarrett
I have the same model, but from 1987. I was wondering if there would be an advantage to removing the auto injector and just run a mix?:confused: I have heard that the auto injector robs some power, and there is always the risk that the auto injector may clog. Is any of this true? How would I disconnect the auto injector?
-Matt
