ab59
Ensign
- May 10, 2017
- 988
I have locked up steering on my 88 starcraft w a 5.7 and cobra sterndrive. My problem is that the pin at the transom end of the cable is frozen and not wanting to come loose. Yesterday I wrapped my hoses up in tin foil and turned a heat gun on the yoke and pin along with a 6" clamp as tight as I could get it hoping it would pop loose, no dice. Then I stepped up to a small hand butane torch and heated it until I got nervous about starting a fire with the clamp tight and no progress. Then I took the clamp off and heated it again and beat on it with a bigger hammer but once again it did not budge. I did these things after soaking it good with PB blaster.
I tried to get a puller on it from the bottom hoping to press it out but there is just not enough room for that set up .
Anyone else had this problem and found a way to make it pop loose ?
