Harritwo
Thread starter- Joined
- Oct 4, 2011
- 586
I bought a 1988 Bass Tracker w/ a 55 HP Nissan Outboard with electric tilt. The boat had been sitting for 3-4 years after the original owner had passed away. When i bought it, i put a new water pump impeller in. The engine has a miss at idle, and under full throttle it will only turn up to 3000 rpm and is struggling. If you will continue to run it, it will clear and come up to 4000 rpm. I have changed plugs and tore the carbs down. Everything looks good.
Does anyone have any suggestions on what to check next?
Also can anyone tell me what engine i actually have. THere are no numbers on the motor, the title has a state assigned ID. THe cowling says 55 and Nissan. See pics and any help is greatly appreciated.
