matthewcaine35
Thread starter- Joined
- May 29, 2018
- 6
hello all, ive been searching for an answer to this ignition problem for a long time now and ive had enough where i had to join and ask this specific question myself. so i just bought a center cosole with a 1988 mariner magnum 150 and i took it out on the water shortly after some cleaning and minor repairs/checks. replaced the tilt pump, started on dog ears to check engine state and gears shifting properly. i took this boat out and it always cranked good but it did have a wierd super short spurt of high idle almost like a cough... anyway, went into gear fine ran fine but did get a little hot (my guess is due to previous people pulling out thermostats) so that trip was good and i figured i had a good motor. 2nd time around i took my wife and kiddo to the lake and the motor cranked but lasted about 10 secs before it died and did this repeatedly until i decided to put it in gear and see if giving it some gas would get whatever bug it had shaken out. well it started off good. i kept it at about half throttle just cruising and all of a sudden, DEAD. hasnt cranked back up to this day. first thing i did was check spark. didnt have spark so i researched and researched until i ended up buying a new stator. so as of right now i have a new stator that doesnt seem to be outputting hardly any ac voltage. i understand you need a dva to properly test output but i have a really good volt meter that records peaks and the highest it got was like 1.5V ac. i know for a fact i have the correct stator, ive triple checked but for some reason it appears im getting some rubbing on the inner flywheel/ outer stator. im pretty sure this is what is hindering my voltage. my question is, WHY in the heck would it be rubbing? and since ive been cranking on it for a while, should i expect this stator to be bad??? im going to try to add pictures of some of the things that i find suspicious. for example, when i pulled my flywheel the first time i found what appeared to be burn marks where it looked like the mating surface of the underside of the flywheel meets the top of the crank shaft. and it looked like the arc tried to travel towards the magnet. I’m out of ideas
