1988 Lund Pro V 1700 interior rebuild
lokonn
Re: 1988 Lund Pro V 1700 interior rebuild
The staple gun will depend on the type of adhesive you are using. If it is a high tack adhesive staple gun may not be needed. Low tack will require staples to hold carpet in place until glue dries.
thiker15
better to use a marine grade contact adhesive. bonds faster
lund prov
Alright, all the pieces are carpeted and it is time for reassembly. But, I am having trouble with my rivets. The mandrel is pulling all the way through my rivets, so I have figured my rivets are too short. My question is, can I just use self-tapping screws to fasten to the stringers under the floor? I have rivets that are supposed to hold up to an inch, and the floor is 3/4" plywood, epoxied (not sure if this matters), with carpet over the top, the stringer underneath is about 1/8" thick, so I thought a 1.2" rivet was long enough, but it must not be, Looking for fastener ideas. Thanks
jigngrub
Self tappers are fine, use stainless steel though. Even coated exterior grade screws will rust in a boat over time... ask me how I know.
Your carpet is easily another 1/4" of thickness if it's the foam backed marine type.
thiker15
I agree use stainless steel screws but I pre drilled my first. what happens when using self tapers is sometimes the hole through the deck becomes bigger, thus the reason for pre drilling
lund prov
Cool, that is a relief as I have several holes to deal with after trying the rivet thing. Back to work tomorrow. Thanks for all the help and advice. With a little luck I will have the boat out before it is too cold.
