crabby_bob
Thread starter- Joined
- Mar 22, 2007
- 58
My brother and I were scooting across Buzzard's bay a few weeks ago and we hit a wave pretty hard. We took quite a bath over the bow and after that the motor started to overheat. The first time it overheated we limped into a harbor and let it cool for about 20 minutes. We headed back out to the bay and didn't get far before it overheated again. We were able to get the heat down by throttling the motor back to less than 2000 RPMs, and rode it back into the harbor where we pulled it out trailered it home.
We don't know where to start troubleshooting. My brother suspects the pickup tube that goes from the pump to the head might have been dis-logged. We replaced the water pump last year to fix an overheating problem and noticed that the upper part of the tube was pretty corroded, so I'm planning to drop the lower unit in the next few days to check it out. But we're still getting water out the check valve so I would think the tube is still connected.
What other things can I look at? Would it be worth taking the pump apart? Is it possible the impeller was damaged? We hit a few waves where the motor would rev up pretty high, much higher than the 3500 or so RPMs we were running at.
