mnewcomer1
- Feb 5, 2012
- 2
I have a Johnson GT150 (1988). I had carb rebuilt, new plugs also. It ran fine however, it would bog down at full throttle. It almost seamed like it had a second gear. Sometimes it would run 58mph, but mostly 48. Someone said to change plugs because sounded like one was fouling out. I check plug wire and they seem ok. I just started it and checked fire to each plug. All had fire except one. But when I pulled each wire loose when running. the engine didnt really change in sound but only for one and it almost died. Is this a coil problem??? Help please.
