Chuckdeezel
Thread starter- Joined
- Apr 19, 2017
- 10
I have a 1988 johnson gt 150 on a 1989 nitro 1800tf (17ftbass boat). The idle is a little low but it sounds like it runs good through all rpm ranges. I have tried 2 props. First one is a 14 1/2 24p raker. When I throttle , i hear the the engine rev up nice and fast, but the rpms on the tach barely move up until im on plane which takes about 8 seconds. The boats bow rises high ,revs high then planes out. Then it runs good to a wot of 4400 rpms at 53 GPS mph. Its tilted and trimmed properly . Way too low rpm, so I tried a second prop.
Second prop is a 14 3/4 19p viper. With this prop the boat jumps out of hole in about 3 seconds and runs strong to wot of 5200rpm 45 gps mph. This motor should be a lot stronger. Compression is within 5% of 80 on all cylinders. I have replaced all fuel lines. The bulb feels firm. Tach is new. I put new champion ql77jc4 plugs in. What gives? Could it be a coil or cylinder not firing causing it to have lower hp? It sounds like it runs good, just not on performance.
