1988 Johnson gt 150 with low hp output
Chuckdeezel
I have a 1988 johnson gt 150 on a 1989 nitro 1800tf (17ftbass boat). The idle is a little low but it sounds like it runs good through all rpm ranges. I have tried 2 props. First one is a 14 1/2 24p raker. When I throttle , i hear the the engine rev up nice and fast, but the rpms on the tach barely move up until im on plane which takes about 8 seconds. The boats bow rises high ,revs high then planes out. Then it runs good to a wot of 4400 rpms at 53 GPS mph. Its tilted and trimmed properly . Way too low rpm, so I tried a second prop.
Second prop is a 14 3/4 19p viper. With this prop the boat jumps out of hole in about 3 seconds and runs strong to wot of 5200rpm 45 gps mph. This motor should be a lot stronger. Compression is within 5% of 80 on all cylinders. I have replaced all fuel lines. The bulb feels firm. Tach is new. I put new champion ql77jc4 plugs in. What gives? Could it be a coil or cylinder not firing causing it to have lower hp? It sounds like it runs good, just not on performance.
flyingscott
Sorry the website kicked me off so I will finish my thoughts. Your compression is on the low side for your motor.
Chuckdeezel
From what I've read on other forums that 90psi to 80 is perfectly acceptable because these motors have lower compression. Anyway I just did a test with a ignition spark tester , followed an old forum members advice by the name Joe Reeves . I set the spark gap to 7/16ths and found all but one had strong spark , one had none. Purchased a coil online and it will be here monday.
boobie
If the coil does not do it go to cdielectronics.com. for trouble shooting advice.
Bosunsmate
Joe Reeves, he got in a huff and took off a while back, bit of a shame, hope hes ok.
Clean your coil grounds too
First reply he got on another forum suggested it might be running on 5 cylinders !
