walkinstick
Thread starter- Joined
- May 17, 2010
- 4
I have a 1988 johnson 88spl that will not idle. I have checked compression [125+ all 4] spark jumps 3/4 inch gap, rebuilt and eventually replaced carbs, checked and replaced hoses as needed, rebuilt fuel pump. finally gave up and took it to the shop and was told my lower crank was bad nd was causing my problem. I brought the boat home removed power head and found base gasket had blown out and leaking into water jacket, main seal seems ok but will replace anyway,why not. My ? is this, could the gasket or the lower crank seal be causing this motor to not run at idle. thanks
