gnarbrah
- Sep 20, 2007
- 140
Hi all - Long story short I have this motor and it's driving me crazy. If you look back at my other posts you'll see the progression. Current Issue - I took the boat out 2 weeks ago and it ran great! 1 week ago I went out again and it wouldn't run right. Basically it started up and I idled out then when I throttle up it dies. I brought it in and thought I found the problem which was the butterfly in the carb. At full throttle it was just over halfway to horizontal. I adjusted it back to where it was horizontal at full throttle (why would this have changed in 1 week after it ran great? - I have no clue unless the set screw was loose somehow?) and assumed this was the problem. Excitedly I took it out today and it ran even worse. Occasionally I got it to idle nicely but it would never throttle up. To get it to idle I had to prime then adjust the slow speed needle to about 1/2 to 3/4 turn out from fully closed. I know the book says to start at 3.5 turns out and adjust from there but I couldn't get much with it that rich. What could cause the motor to just die out as soon as I try to throttle up? I rebuilt the carb last July or so and I'm hoping that should still be ok. I figure it has to be fuel / air problem or spark. What else is there and where to begin???
Thanks!
Thanks!
