1988 Johnson 175 hp low compression
paxman
I recently acquired a 1985 Champion Super V 18' in very good condition with this non running Johnson 175 hp motor (J175TLCCM). Compression is 75 on 5 cylinders, but 35 on the middle starboard cylinder. I am seeking input if this is a good candidate fo repair or if I should seek a different motor? I have never rebuilt an outboard, but have built many high performance car engines. I have experience with smaller Johnson 9.5 and 35 hp motors as far as carb rebuilding and ignition troubleshooting. I'm told that normal compression for this motor should be 90-100 psi. If this is a good candidate to repair or rebuild what are my next steps to determine this. Also, the power tilt is not working when I direct connect 12 volts. It clicks, but does not move. Looks like a new tilt motor is about $130, but guessing there could be deeper problems in the hydraulics. I have an opportunity to purchase a mid 90's Yamaha Pro V 150 with all hardware for $2k. Need help determining best path forward.
The only information I have is that previous owner was going down the lake at 1/2 throttle and motor suddenly died and would not restart. He then traded it to the guy I got it from for a newer boat. Thanks in advance for any help.
flyingscott
Buy the pro v not because the 175 is a bad motor but because you get newer and a great motor for probably less than the rebuild will cost. The yamaha will be a looper as compared to your crossflow but make sure the yamaha is in good running condition.
emdsapmgr
Check some things before you give up on the crossflow. 1. pull the heads and make sure that the problem is not with the head gasket. Once off, you should be easily able to determine if the compression seal ring of the gasket is good/bad. If it's bad-that could be a real cheap fix. If the prior owner ever overheated it, (which may be exactly why it stopped for him.) That can damage the head gaskets, even warp the head. Check that out first. You may only need to plane the heads and new head gaskets. 2. There is a power trim control box mounted on the back of the engine on the exhaust manifold. Inside are two trim relays, one for up, the other for down. The trim won't work properly if you don't have both working properly. They are cheap to replace-make sure you replace both, not just one. 3. I would agree, the compression on that engine should be 90-95 lbs. You can run a can of Bombardier Engine Tuner through the engine while it is idling, and the compression may come up a few lbs. No reason you can't give it two applications of the aerosol tuner.
paxman
Thanks for the input guys. I will remove head and hope for blown gasket and go from there.
Faztbullet
If its the hump back 175 its a 3.6 bore and they are prone to crap a cylinder as sleeve is to thin. These are due to cooling issues as this motor needs a impeller yearly no matter how good its peeing...
emdsapmgr
It's possible that the engine suffered an overheat with the prior owner. If the engine ran overheated, the piston can heat up (swell) if they run too long in that condition, the pistons can lockup inside the cyls. Called a high rpm overheat lockup.
