27hamilton
Thread starter- Joined
- Jun 23, 2018
- 2
I redid my boat interior and had to remove the controller which put you boat in forward and reverse, also has trim switch in it. I accidentally put the switch back in upside down so when you pushed up the trim went down when I pushed down it went up.. no biggey it was just opposite, well the trim quit working... not sure where to start, the trim motor is mounted in the right rear and kinda difficult to get to I have seen some posts about the blue, green and black wire should I us jumper wires and test the trim pump first and work my way back to the solenoids and ultimately the switch or should I start at the switch and work back?
