21BaylinerCC
Thread starter- Joined
- Jun 17, 2015
- 48
So I finally got my boat out on the water this weekend. The engine started right up and idles fine. Had to adjust the idle screw in order to shift from neutral into gear. Got it out of the marina into open water, gave it WOT, and bogged down after about 8 seconds of running strong. I noticed that when I would run it in WOT and prime the fuel bulb, it would stay running at WOT. Any ideas?
I am thinking it's either carbs or the fuel pump assembly. I already checked the fuel vent to see if it was clogged, the primer bulb had resistance, and it's new gas treated with Quickleen and marine Sta Bil.
