1988 evinrude SPL 28 hp problems
rileychad
my motor has an issue and I don't know what it causing it when I crank it it runs good but then wants to die after a few seconds and I can put the choke on and it will rev back up when I let off it and then it will start to go dead again and I can do the same thing and it work
any suggestions
thanks
cr
woodstockmarine
Maybe an easy fix but the floats may be sticking. Usually the floats push up on a brass rubber tipped spring loaded plunger or valve this could be gummed up with old fuel and may not be opining all the way starving the carbs of fuel. I would remove the bowls and floats and remove the plunger and clean the parts and make sure the plunger moves freely. won't take long and it is the easiest thing that I can think of to try first.
ondarvr
Dirty carb, common issue, pull it off and clean it.
rileychad
where would the bowl be on this carb
also sometimes it seems like it backfires
thanks
cr
jakedaawg
The bowl is on the bottom of the carb. This carb can be a little tricky to remove. I suggest you find a parts blow up so you can find the three screws needed to remove the starter bracket thingy thats in the way.
tphoyt
Good Day
If you don't know where the bowl is then get your self a service manual and it will tell you how to rebuild your carb.
It's an easy job and "WILL" need a carb kit to do the job right.
