bigeasy8240
- Mar 24, 2008
- 3
Hello!
I'm new to the posting forum, but have been lurking around the web site for quite sometime. This website has been very helpful and I do thankeveryone.
I have a 88 Evinrude 48 SPL that came with a boat I purchased about 2 months ago and now that I have had it out on the water, it would not idle. I rebuilt both carbs and checked the fuel pump, bulb, gas tank and gas, vented the opening and tighten down the coils that were loose. Now, not only will it not idle, but it is backfiring!
I'm thinking that it may be either the condenser, coil armature or something that has to do with the electrical system. As I've been researching, the electrical system is the weakest link! The first time I took it out, it would not get up to speed until I pressed in the key to give it a little more gas then it pepped up a little, so I rebuilt the carbs, it still would not idle but I did gain more power out of the engine. 2nd time out it ran pretty well for approximately 25 miles and then starting loosing power and when I give it throttle it starts backfiring and sputtering. Let off the throttle and it somewhat stops.
Any ideas or suggestions would be greatly appreciated. :redface:
