Boat - 25' Aquasport walkaround cuddy
Motor- 1988 evinrude 225 v6
I was Having a problem with low power and poor idling, after it had sat for nearly 2 months end of last season, pulled it out and winterized it.
Drained the fuel, changed fuel filter, all new plugs, added fuel stabilizer to new gas.
Started it up and running nice (out of water), and sprayed out carbs with carb cleaner.
I then tested compression, 60,60,62, 60, 62, 62.
Are these considered low comps? I was under the impression that I didn't want to below 90 and within 5 across the board.
Should i just put it in and run it and see what happens or should I swap out the head gaskets and take a look at the cylinders, pistons and rings?
Thanks,
Josh C - RI
Thanks,
Josh C - RI
