1988 Bravo 1 Not going into gear
Nedlucas
Hi - At the end of last season (on my very last ride) my Cobalt 21BR gave me a hard time going into gear. Couldn't get it into reverse and once I got it into forward, I had very little throttle throw. The black plastic center piece on the throttle arm won't pop out. Any thoughts? Thanks in advance.
tpenfield
Greetings and welcome to iBoats.
Have the Moderators move your post to the Mercruiser section, since you are talking about a Bravo 1.
It is not clear if you are having a problem with the shifter/throttle control lever thingy or the outdrive itself. Check your control mechanism and the shift adjustment at the engine (there is a special too for checking/adjusting the shift linkage)
If it turns out to be the outdrive, then there is a common repair item as the cone clutch within the Bravo ages, becomes glazed, and does not engage properly. There is a 'poor man's ' fix and then the prescribed fix, which is to replace the clutch & gear set in the upper portion of the outdrive.
B.T.D.T. and I chose the poor man's approach.
Nedlucas
Thanks for the suggestions. I’ve requested the thread be moved. Also, what is the poor man’s fix you mentioned?
alldodge
It has been moved
The issue I'm having is what parts your talking about
If the above is actually what the issue is, then its a control issue and not a Merc one.
If the button wont pop out then need to get into the throttle handle
