1988 Bayliner Project
boedekerj
At the recommendation of kcassels (who has rendedered fantastic advice for me before), I'm jumping in the right way, and posting my project.
Like many, I went out to pick up a "great deal" of a boat. Like many, i found out too late that it wasn't. The outboard had been recently serviced, and was operable, but the owner seemed to not know ANYTHING about boating. (When I looked at it, I asked "where's the bilge plug?" The answer was, "It didn't come with one...") The boat had been (poorly) primed and painted, but the floor seemed very stiff, compared to previous boats I'd examined. After offering what I was sure to be an insult, the gentleman's wife urged the man to accept, and I picked up a boat, trailed and operable outboard for $500.
Of course, getting home and pulling some things to thoroughly clean the inside and outside, I found...
and second floor, with nearly identical carpet to the original.
Fast forward; The rot didn't stop at the deck, or the foam, or the transom, or the stringers.
So, I started measuring and gutting.
I'm posting this project about 2 months into the progress. The project started in August of last year, and had to stop in October due to the temps of Iowa. (No more glassin' under 60 degrees.)
As I type this, it's 25 degrees on April 1st, and I can't wait to get out and finish up this project.
Pic's attached are mostly in order of date, however, I don't have any "post seacast pour" yet.
Next steps; Grind back the stringers/bulkheads around the fuel tank, then add a layer of 1708. (Due to having to overgrind the stringers for tank fit.) Then, sand, clean and two-part epoxy prime+paint the tank prior to install. Then install floor, re-cap, and start the "re-install" of the seats and other deck fixtures.
More updates to come, and thanks to the "all over the place" questions I've been popping in other folks threads. It's all been very beneficial to me.
Pics are coming....
boedekerj
[No message]
boedekerj
[No message]
kcassells
Hey Bo...Great to see you posted a thread. I've seen the vid. When are you going to pour the seacaste? So now you can keep all your questions here on your thread.
sphelps has a few threads with seacate. He may be your go to guy. Hi Sam! :D
boedekerj
Already done, man. I didn't video the actual pour, because I didn't have enough hands. :)
I'll put up some "after" pour/current state pics when I can get this thing out, finally. I am just bored to death with all of this cold.
sphelps
The pours are usually pretty uneventful .. Make sure you use all the paste hardener as the instructions say .. It helps to have an extra hand for adding the fibers while your mixing .. Other than that just mix and pour ... It;s not as runny as you would think ... Rubber mallet to tap on the skins to release any air .. Boedekerj looks like a great prep job to me ! How many gallons did it take ?
boedekerj
Thanks sphelps! 10 gallons. And it was ALL of 10 gallons with no leftover. I have to say, this stuff is TOUGH. After it cured, I took a 5# hammer, and swung it at the bulkhead, and it bounces off it like it's hitting an Abrams tank. I wish I could afford the self leveling SeaCast for the deck, but from what I calculate, it would take another 16+ gallons, and take the budget for this WAAAAAY over.
Big Gee
Looks like a great project. :eagerness:
I'll follow along with interest.
dezmond
A great tip when pouring seacast for a transom that I did is to us a palm sander with out the sandpaper to help get the bubbles out. It worked great for me when I poured mine years ago on my first project boat.
Have fun with the build. I have a ''89 Capri 1750 that I will be ripping apart in the next few weeks.
sphelps
Desmond I was told by Sabina , the sea cast owner , NOT to vibrate it with a sander .
It separates the fibers from the liquid and they settle down . You want the fibers to be uniform in the mix though out .
I had the same thoughts about vibrating it so I asked . She said deffinataly don’t vibrate ...
boedekerj
I'm grateful to have the attention of some previous SeaCast users. Even though my pour is over and done, I'll have some questions in the coming weeks you guys might be able to help with.
While I didn't vibrate, surely I have to think that brief vibration would help to get air bubbles out without causing separation?
Sabine is a fantastic resource. That said, there were sometimes that her advice had me like; "Seriously? I'll do it, but dang, this seems a bit much." I dunno. I always followed the advice. I don't know about your experience, but it took some photographic and video PROOF to get her approval for me to even place the order for SeaCast. I'm not sure if it was paranoia, experience, superb quality assurance, or some combination thereof. I guess in the end, it doesn't matter. You can't shoot through the stuff with a .22 (per other users), so I imagine it'll last forever. And even if I thought she was a bit paranoid, she certainly made sure that you cut NO corners.
I will say this; I will probably never gut/re-string a boat differently. That extra $300 (difference between wood or SeaCast transom/stringers) is worth (to me) the peace of mind, even if I don't own it forever. I will never have to worry about a rotten transom busting off of a boat that I re-worked, stranding (or worse, drowning) passengers.
...admittedly, I'm a paranoid dude when it comes to safety. Same reason I can't sell a car with dodgy brakes, or worn ball joints/tie-rod ends. If something happened afterwards, I'd feel horrible, even if I warned them.
kcassells
Did you ever take pics after you poured the stringers etc. Id like to see them if ya have them.
Women and vibrators in the same sentence, can't quite put a finger on it.:joyous:
Davetowz
Glad someone else went there first. :)
boedekerj
Ay-yoh!!!! Once I get a decent day, I'll take pics and post. It's in the same spot as after the pour. It won't break into 50 until next Sunday.
kcassells
Don't mind KC .. He's just been hanging out with Micky for too long ... :rolleyes:
mickyryan
Hey yo? Micky I dink we just got dunked?:happy: It's the Micky Kev Show. :D
images
boedekerj
Update: Boat floor complete, tabbed/glassed in. Here are pics of post-seacast, pre-floor install. The stock Aluminum tank held 50 PSI of air, so I figured it was still good, although it was showing signs of corrosion due to absolutely CRAPPY factory install. (Water just sat on the top of the tank, causing decent pitting.) I light sanded (220 grit) the tank, hit it with vinegar, then painted it with 2 part epoxy high-build aluminum paint.
Question to any who may still remember this project; When joining the top and bottom hulls, where do I apply the sealant? At the bottom where the caps meet? do I draw a bead on the bottom/inner hull and then drop them together? The factory appeared to use clear silicon, and only under the aluminum trim ring on the outside of the hull seam. I've got plenty of 5200, but don't want to use it if it's not prudent to do so.
ALSO, The cap does not line up perfectly. It's about 1/16" off from the old holes. Any tips for shifting the cap to the stern without cracking the glass?
Thanks ya'll!
