1988 bayliner 85 hp
joeroe
Ran fine last year but can't get it running this year
aladin_sane
Re: 1988 bayliner 85 hp
We may need a little more information. What exactly does it do when you turn the key?
joeroe
Ran fine last year but can't get it running this year.... It turns over but won't start I drained the gas and put in new gas and changed the spark plugs! Please help
mauiboy
Do you have spark, dose it want to start or dose it just crank. I would start by checking if it has spark, if not check your safety switch where your lanyard to the key goes. make sure it is in nutral. If you have spark then check your fuel pump then your carbs.
