When a crossflow gets a lot of hours on it, the pistons wear in the bores. When it gets really worn, you can hear pistons slap when the engine is running. This is normal, caused by the piston skirts slapping the cylinder walls as the engine rotates. More evident at lower rpms. Undistingushable at WOT. Though it may sound bad, it is not a sign that the powerhead will fail in the near future. If you were to overbore it and put in new pistons-that should resolve that problem.
