1988 88 spl temp gauge?
lvl
Is it possible to put a temp guage on an 88 88spl? If so is it worth it?
ezeke
Re: 1988 88 spl temp gauge?
It's a good idea to have a temperature gauge because it gives you a way of monitoring the effectiveness of the cooling system, rather than depending on the warning horn, which often comes too late or at an inconvenient time.
Each gauge requires its own special variable resistor sender and wire. The sender would be mounted on the cylinder head using one of the cylinder head bolts and a Z bar. Be sure to order the kit rather than just the gauge. If you want to monitor both banks of cylinders, you would need either two kits, or two senders and a switch.
http://www.downloadingfiles.co.uk/teleflexfiles/gauges/Outboards.pdf
lvl
Thanks that was very helpful. That was my take on the whole waring horn too.
