1988 50hp carbs
fritzalouie
Is the removal and cleaning of carbs off 1988 50hp similar to the ones 0n a 1990 50hp ?.The manual I am using is from 1990 -96.
Toddboat
Re: 1988 50hp carbs
I'm sure it's close enough that you'll be able to take them apart and clean them and put them back. Link and sync procedures may be different, though. Still learning about that myself. You should probably bathe the carbs in carb cleaner (with all rubber and plastic parts removed) for a couple days, rather that just spraying carb cleaner through the holes you see. There are very tiny holes that you don't see that could be clogged. The bath cleans these holes better than a spray washing.
fritzalouie
Re: 1988 50hp carbs
On the 1988 the main jet has no way of removal that I can see.No slot for a screw driver or interior threading for for a jet removal tool..Any ideas?
99yam40
Re: 1988 50hp carbs
hard to believe they are not removable, but I have never looked at one to make sure
fritzalouie
Re: 1988 50hp carbs
Oops,they just come out in a different way than I read.
Yamaha mechanic showed me,also mentioned if the brass jets were showing green to use oven cleaner .
