I have a 1988 3.0 which was running fine in my driveway (fairly new boat to me). I then trailer it over to the lake and it refuses to start. Looking down the carb it looks like it was just dumping fuel. I had figured I had knocked something loose driving over. It would almost start and sort of chug and even run for 5-10 seconds but just barely, almost as if it was running on one cylinder but not exactly.
Ended up pulling the carb and cleaning it out (not a rebuild), it had some serious chunky stuff in the fuel bowl. Oddly I can imagine it clogging things up but couldn't quite figure out how it would cause it to go so rich, on the other hand who knows what might be clogged. I will be rebuilding it in a bit since I need to replace the gasket anyway; I can only find a rebuild kit and not just the gasket itself.
I need to triple check the ignition to make sure I am getting good spark at all the cylinders (which I am pretty sure I am) but I need a helper for that. It is definitely getting good fuel to the carb (new gas, fuel pump working well).
But I really think it is just dumping fuel. When I pull the carbuerator there is a pool of gas in the intake manifold and it just looks soaked looking down the carb. Does anyone have any suggestions on what else to look at on this carb or engine?
